johnson 130 idle problems
josip77
hi
engine is bj130plss,problem is with idle mixture,when idles mixture screws are set 3.5 a turn out at the moment engine turn off at idle,when i put about 5.5 screws are seta turn out at the moment then can work at idle,but not perfect,is posible the air leaks somewere??when try starts engine sometime engine know sneeza.I test compresion ,and is about 126psi on all 4 piston...
any advice?
thanks
tashasdaddy
Re: johnson 130 idle problems
you don't say what year or model. is suspect dirty carbs.
josip77
hi
2000 year,I clean and rebild all carb....
thanks
Walker
My memory isn't the best but I seem to recall a service bulletin that changed the specs from 3.5 turns to 5.5 turns.
