NealLauderman
- Feb 12, 2007
- 191
Fellas,
I am having issues installing the lower unit back as I dont want to do it incorrectly. I have knocked the shift rod outta adjustment and am trying to correct it.
The service manual I has tells me to adjust it to a certain height by turning it but how can I check to make sure it is at the correct length other than hoping my measurements are right? I dont have the correct tool to measure it and am just using a tape measure.
One last thing, when putting the lower unit back on, I should have everything in neutral correct? I know when I was trying to install it before, the big fat rod was hitting something and not going all the way in and I was told to play with the prop handle thing but if its all in neutral that wouldnt do anything?
