  #1
Old May 12th, 2007, 10:53 PM
Essekks Essekks is offline
Default Evinrude 9.9 wont start in spring
I am not that knowlegeable about motors. I had pulled out my boat to summerize it and fired up all the motors using a water pump. ( I did all the proper winterizing last fall, the motor is in good shape, etc)
When I tried to start the 9.9 it started up fairly quickly, ran for awhile (long enough to get all the fogger out of its system and clear up all that smoke) but then died. I then was never able to get it started (I was as if no fuel was getting to it). I tried pulling with the choke out, the choke in, pumped the gas ball (it was rock solid), waited an hour...kept pulling till by hands blistered. no dice.
I remember having the exact same issue the previous spring and took it in, paid $150 and nothing was wrong with it...so I vow not to do that again.
Any advice on the proper way to "cold start" a motor? Do you keep pulling with choke out? How do you know if its flooded? What do you do when its flooded? Is there a way to make sure its getting gas in there?
Need some newbie advice.
(Motor is a 1996 Evinrude 8hp)
  #2
Old May 12th, 2007, 11:09 PM
iwombat's Avatar
iwombat iwombat is offline
Default Re: Evinrude 9.9 wont start in spring
You might just have some fouled plugs after burning off all the fogger. Clean 'em up, or replace 'em and see what happens.
  #3
Old May 13th, 2007, 02:09 PM
Thanks, I will give that a shot. Another question about flooding the engine. How many times should I pull the cord with the choke out (assuming it won;t start) before I have to be worried about flooding? Also, how do I know if the engine is flooded?
  #4
Old May 13th, 2007, 03:21 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
to verify flooding, pull the plugs, and if wet, also check spark. read this:
http://forums.iboats.com/showthread.php?t=158071
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #5
Old May 13th, 2007, 04:01 PM
BoatBuoy BoatBuoy is offline
My 2-stroke starting procedure:
Open the throttle, choke it, crank til it burps or fires at least once on one or more cylinders. Then "un-choke" it, leave the throttle open, and crank til it either starts or burps again. If it burps without starting, close the choke and repeat. If and when it starts, you may have to juggle the choke off and on until it runs without juggling the choke. Unlike carb'ed automobiles, the carb doesn't have an accelerator pump and flooding is less likely.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude wont start DARKCLOWN Johnson & Evinrude Outboards 12 September 5th, 2006 05:25 PM
Evinrude 78, wont start Angiecobia Johnson & Evinrude Outboards 3 March 30th, 2006 05:37 AM
Evinrude 90 hp wont start Rudy Brown Johnson & Evinrude Outboards 2 October 9th, 2005 11:26 AM
'82 Evinrude 9.9 wont start wilbur_53 Johnson & Evinrude Outboards 8 July 29th, 2002 05:43 AM
69/70 Evinrude 9.5 wont start FISH HAWK Johnson & Evinrude Outboards 2 June 27th, 2002 07:40 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
