Blown02svt
- Apr 3, 2007
- 4
I just purchased a 2002 Larson Cabrio 274 which has a sink in the galley, a sink in the head, a sink in the cockpit area, and a transom shower. The problem I'm having, is low water pressure. The pump will run to build pressure then shut off once it reaches operating pressure. I get water flow, but when I try to use the spray feature on either the galley sink or the shower in the head, the pressure is so low that it won't keep in the spray mode...meaning the water just trickles out of the nozzle and once the button is released, it goes right back to normal (non spray). This is the case even when I'm trying to use any ONE of the faucets. The transom shower works a little bit better, but I'm wondering if it only does because it's closer to the pump.
Anyway, I'm just curious as to whether or not I have a bad pump incapable of building and maintaining the required pressure or if it's another problem that I'm just not aware of.
The pump that's installed is rated at 2.8 gpm and 45 psi and is the original pump installed on the boat from the factory. The boat only has 100 hours on it and I'm seriously doubting that the water system was used much.
Any help would be greatly appreciated!!
Thanks.
Thanks.
