  #1
Old May 10th, 2007, 08:14 PM
Tinlizzy Tinlizzy is offline
Default 1960 75 HP Evinrude Compression Help
Hi guys!
I did a compression test on my 1960 75 HP Evinrude V-4. I have 65 lbs in cyl. 1&3 and 55 lbs. in cyl. 2&4.
The motor has not run in 13 years or so and I am trying to decide whether or not too fix this motor up, so I started with the compression test. I pulled the heads off and cleaned the cylinders up and the tops of the pistons, there are a few scores in the walls and some rust corrosion from being exposed by a previous owner.
I put the heads back on with old gaskets just to get an idea on the compression. They seated well when I torqued them down. ( I have two new gaskets for it waiting) Is it worth it to put the new gaskets on, clean the carbs out and rebuild the water pump etc, and try to fire it up based on the compression test?
Thanks for the help!
  #2
Old May 10th, 2007, 08:30 PM
F_R F_R is online now
Default Re: 1960 75 HP Evinrude Compression Help
Remove the bypass port covers from the sides and check the rings for being stuck. They probably are. You can also see the other sides of the pistons through the exhaust ports under the cover between the V. Guessing you are looking at a complete teardown.
  #3
Old May 10th, 2007, 08:47 PM
Is that considered low compression for the motor? I do not have a reference chart. The pistons move freely, I am not thinking the rings are stuck...And I do not know if they will seat anymore seeing the age of the motor and how much they have expanded allready.
I am trying to get away without a complete rebuild due to parts availability...
  #4
Old May 10th, 2007, 08:52 PM
Yes, that's low. Why don't you think the rings are stuck? It's not a matter of expanding or seating. They are stuck in the grooves from carbon and /or rust. God knows it's old enough. But wishful thinking is OK, I guess. Good luck.....
  #5
Old May 10th, 2007, 08:57 PM
ahh now I understand...hmmm maybe I will be running down to the marina and buying a new outboard..
  #6
Old May 10th, 2007, 09:10 PM
samo_ott's Avatar
samo_ott samo_ott is offline
If you did get it going, you'll be going thru gas by the boatload! Literally!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
compression relief valve question for a rds 22 1960 40 hp johnson pinto 21629 Johnson & Evinrude Outboards 1 October 5th, 2005 10:31 AM
compression for a 1960 johnson 5.5 motor kingstond Johnson & Evinrude Outboards 1 June 21st, 2004 09:47 AM
1960 5.5 evinrude, how to??? yakimicki Johnson & Evinrude Outboards 3 May 1st, 2004 03:31 PM
1960 evinrude 40 HP Mathias_Morgan Johnson & Evinrude Outboards 1 August 30th, 2002 03:27 PM
1960, 40 h.p. Evinrude-won't run Denny's Girl Johnson & Evinrude Outboards 9 August 18th, 2002 08:55 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
