I started to see water in the upper unit after running it full speed. Also the motor dies in neutral when I have the cover on. Doesn't die with cover off (but keeps missing a bit). I tried to adjust the idle mixture screw, no changes.
How do I ged rid on the water problem?
Looks like there is rubber gasket around the cowl (bottom), it it the one I need to change? Can I change without taking the upper unit apart?
Thanks.
Thanks.
