mercruiser gaskets
picker523
Does anyone know the best and cheapest place to buy outdrive gaskets? I need the o-ring between outdrive housing and transom and the one between the foot and outdrive housing for my mercruiser.
picker523
Re: mercruiser gaskets
Oh.. I forgot to ask... The bottom bolts(with the anode caps) on the outdrive housing seem to be made out of some other kind of metal. What is this and can I use a regular steel bolt if I'm only running fresh water?
The Gasket Sets are available from Right Here at iboats,..........
Or,....
They can be found at your local NAPA,.........
The 2 bolts at the bottom of the Transom Shield are made of Aluminum,......
And,......
No,..... Don't use Steel bolts,..... Get the Right 1s, they're part of the Bonding System,+ are Needed.....
Freshwater or Not.......
