  #1
Old May 10th, 2007, 11:23 AM
shipwreck's Avatar
shipwreck shipwreck is offline
Question evinrude 3 wire tilt motor repair help
I have 3 wire tilt motor for the 1970 , i need to troubleshoot. it is wired up directly the battery and dose not work.. it make sounds and dose not move when power is applied by using the switch in any direction. i have 12v a battery and other systems on the boat work. the switch test good use meter (beep)
in both direction.
low/ no fluid in motor will it cause not to work?
Dose anyone have a good readable schematic? FOR 3 wire tilt motor?
Dose this 3 tilt system require solenoids? or can you hook up directly to the battery?
looking for the next step to troubleshoot
thank you
  #2
Old May 10th, 2007, 11:37 AM
throwback2332 throwback2332 is offline
Send a message via Yahoo to throwback2332
Default Re: evinrude 3 wire tilt motor repair help
Should have a black control box with a solenoid in it, also hot and ground wire straight to the battery and 5 smaller wires going to the tilt/trim switch and indicator. Try taking the wires straight from the pump and hooked the black to ground and the green or blue to hot, NOT AT THE SAME TIME. Black -/ green +, then black -/ blue +.
  #3
Old May 10th, 2007, 11:43 AM
shipwreck's Avatar
which is ground... it sound like black?
hook the that negative the add one of the other wires and in should work or the motor is bad? or can the fluid level affect operation?
also , i only have tilt no trim on boat. there are are 3 wire out of motor that run to the switch and split off and run to the battery? can this config. still work?
  #4
Old May 10th, 2007, 11:47 AM
Black is negative (always) with the green or blue on hot side of battery the motor should turn if not burned up.
  #5
Old May 16th, 2007, 11:04 AM
RRitt RRitt is online now
Ensign
enemy of your trim motor is water. of all the systems that I have rebuilt only one motor has been worn out from use. the rest have died of cancer (rust caused by water getting inside). It's a shame, but most trim motors die because a $1 seal gets too old to keep out the moisture.
Hook your motor directly to battery. Black to negative and either blue or green to positive. Do not hook both blue and green to positive at same time. If motor spins but nothing happens then you are either out of fluid or have a worn out pump (aka valve body). If motor does not spin then you prolly have rust on the inside. To fix properly field frame will need replacing or coils removed and old field frame blasted down to white metal. If pump then look for someone who can rebuild it. They're intricate little devices but fully rebuildable by someone with parts and know-how.
  #6
Old May 16th, 2007, 11:14 AM
shipwreck's Avatar
thank for your response , i need to retap the rusted thumb screw some jack into the fill port motor the outside seal show no side of leaking any in the system .
i going to check the inside , i have good background for motor repairs this should be a problem to apply my knowledge to this problem.
thank again
my manual just dos not cover these motor, do have any info on file
  #7
Old May 16th, 2007, 04:55 PM
Ensign
what kind of pump is it? I haven't dug into calco pumps yet so I don't yet know how to fix them. If prestolite then I can bring them back from the dead.
  #8
Old May 16th, 2007, 06:22 PM
shipwreck's Avatar
going over to work on tonight i see if i can find the make
thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
difference between the two wire and three wire trim tilt motor? danandsaraht Force & Chrysler Outboards 3 February 13th, 2007 02:49 AM
removing tilt motor 76 omc 2 wire spinecobb Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 July 2nd, 2006 12:44 PM
1970 OMC V8 engine and tilt motor wire harness tjmccarpenter Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 April 26th, 2006 10:26 AM
Trim and Tilt Motor Wire Fortech Mercury & Mariner Outboards 1 March 4th, 2005 02:23 PM
3 wire tilt motor on 2 wire system Scooter29 Force & Chrysler Outboards 0 June 5th, 2002 09:38 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
