  #1
Old May 9th, 2007, 09:16 PM
00squirrel 00squirrel is offline
Question Gas smell in cabin 240 Sundancer
Greetings,
I just bought a 2000 240 Sundancer and I have noticed a faint gasoline smell in the cabin after the boat sits for about a week. Is this something to be concerned about? If so what do I need to do? I'm worried about sleeping in the boat and inhaling fumes.
  #2
Old May 10th, 2007, 04:56 PM
Scott in MN Scott in MN is offline
Default Re: Gas smell in cabin 240 Sundancer
I just bought a '80 225 and the previous owner commented on a gas smell he noticed while pulling the storage cover off for the first time this year. Turned out to be the gasket on some device (sender unit?) mounted on the top of the tank. He took it off, cleaned off the old gasket and used a suitable gasket making goup to reseal it.
I have not dug that deep into the boat yet to see what cover he was talking about but I don't smell any gas fumes either.
  #3
Old May 10th, 2007, 08:52 PM
Question Re: Gas smell in cabin 240 Sundancer
Any tips for tracking down where the leak is? I got a feeling this is going to be tough to fix!
  #4
Old May 12th, 2007, 05:09 AM
magster65's Avatar
magster65 magster65 is offline
Be careful... any gas smell is a problem. Your boat has a fuel filler and a vent outside the hull.
  #5
Old May 14th, 2007, 07:59 PM
Well I looked around as best as I could and couldn't see any visible leaks... Any thoughts on how I might track this down?
  #6
Old May 21st, 2007, 08:12 AM
magster65's Avatar
Tough one.
It's not likely a corroded tank issue so try running your hands over all the fittings and lines. Smell your fingers (that sounds funny). I'm not sure why it would smell a week after it's been run... something under a bit of pressure after it's shut off maybe. Look closely at the lines after the fuel pump. Is this a carb or efi model?
  #7
Old May 26th, 2007, 10:09 AM
This is an EFI model. Still haven't been able to solve it...I may have to give up and take 'er in for repair.
  #8
Old June 5th, 2007, 03:07 AM
magster65's Avatar
Well... if there's no leaks the only thing I can think of is to check your tank vent.
Maybe a bit of smell stays in the boat with the cover on, it might be covering the vent.
Please post your findings, I'm curious...
  #9
Old June 8th, 2007, 06:24 PM
GaBoy GaBoy is offline
My 27' Sundancer after filling up and stopping has gas fumes in cabin for several days. How do I get to the fill line and vent pipe? Do I have to go through the interior walls or floor? How do you access the tank to check for any problems?
  #10
Old June 10th, 2007, 02:04 AM
magster65's Avatar
Sounds like a similar problem. I don't know if it's the same as yours but the tank in my '87 was accessable by lifting the floor panel in between the seats. The lines are visible there too.
  #11
Old June 12th, 2007, 11:09 AM
Thanks for the help and advice.
  #12
Old June 12th, 2007, 12:02 PM
magster65's Avatar
No problemo!
__________________
Arrrr matey!
'07 Campion 705 sc 5.7 GXi / DPS.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
190 SUNDANCER critter34 Boat Topics and Questions (not engine topics) 5 July 27th, 2006 02:55 PM
268 sundancer darimont Sea Ray Boats 12 July 23rd, 2006 12:06 AM
Removing smell from cabin goodtimes132 Boat Restoration and Building 11 August 17th, 2005 07:03 AM
Fuel smell in cabin VanillaGorilla Boat Topics and Questions (not engine topics) 3 May 7th, 2004 07:23 AM
Used Sea Ray 270 Sundancer sundancer Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 7 September 23rd, 2002 06:54 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
