Re: 1979 V6 150 Mercury Carb Diagram
Your engine has no idle adjustment needles for mixture, if it's bad enough you would have to remove the plugs on the outside of each carb and change the jets, they are air jets so you will have to decrease the size to richen the mix and increase the size to lean the engine. Also you can change the mix a little by trimming the engine, out is lean and in is rich
