78 Johnson 70hp not charging?
ogishere
I dont think my engine is recharging the battery. The Tach quit working , I dont have a reading on the tach signal wire at all. The battery reads 12v with motor running. How do I test the charging system? What would be bad? I have another motor just like it so parts is not a problem.
Thanks in Advance
ogishere
R.Johnson
Re: 78 Johnson 70hp not charging?
More than likely it is the rectifier, but when you change it, check the battery connections. If it has wing nuts', replace with brass, or stainles steel nuts'.
ogishere
Where is the rectifier located and what does it look like? Im kinda new to boat motors. Already use stainless steel on battery. Is this hard to change?
Thanks
ogishere
ezeke
Your rectifier should be cylindrical, with a triangular base. It would have 3 or four wires connected to the terminal block near the flywheel. One of the other wires at the terminal block is/should be gray. The gray wire is the pulse wire that sends the signal to the tachometer.
If you go to the BRP parts catalogs and look up your motor, you can then open the "ignition" diagram and see the components:
http://epc.brp.com/default.aspx?brands=ej&lang=e
You might want to read this thread, where Joe Reeves describes how to test the rectifier. It is near the end of the thread:
http://forums.iboats.com/bbBoard.cgi?a=viewthread;fid=28;gtid=1290805
ogishere
ogishere
Thanks alot this helps tremendously!!
will try it out tomorrow!
Thanks again
ogishere
ogishere
the rectifier was bad. I had an old one on a donor motor but the wiring is dry rotted. Any suggestions on where to order one online? Iboats.com dosent have one. I found one on ebay for 19.99 it has the same numbers as the one I have. It also has a 14 day warranty on it so I think I will order it, only thing is it is used so I dont know how long it would last. Do these go bad pretty often or do they normally last a while?
Thanks for all the help!!
ogishere
tashasdaddy
they rarely go out. just touching battery cable backwards can blow them tough.
ezeke
ogishere
Alright thanks I will just order the one off ebay today!
Trying to get boat ready for first outing this weekend I dont know who is more excited me or my 11yr old son!
probably me!
thanks again this board has been a God send!!!
ogishere
tashasdaddy
did you know there is a cold front coming thru. suppose to be 40 here sat morn.
ogishere
Your right to cold this weekend, I will have to wait maybe next weekend? hopefully! ordered a rectifier through Johnson dealer will be here Monday so I have to wait til next week anyway. My son cant wait he calls the first outing her maiden voyage and named the boat Old Glory! He loves fishing and being out on the lake. We camp alot. Glad the season is back! d:)
sweetmarie
Hi, I'm not doubting your suggestion but why do wing nuts not perform as well as s/s? I'm sure you're going to tell me that wing nuts promote corrosion and loss of contact, but why? I currently have a wing nut on the positive terminal, the wing nut is in good shape so far, been there a few years although I did have to clean the contacts at the end of the wires at times. Do they make s/s wing nuts? Thanks
ps: I recently changed my r/r, wasn't charging.
