2000 50 elpto 0T062237 thermostat
rolmops
I am still working on the outboard which my FIL fried,but it is almost back together.While replacing the thermostat,I found a flat rubber ring in the package and I checked the manual,where it is mentioned as an O-ring.In some pictures this ring sits between the black plastic carrier tube and the actual metal thermostat that has its own very similar rubber ring,while in other pictures is does not feature.Do I need it for this specific engine ?
Thanks for your advice.
