Rocker switch
drewpster
Re: Rocker switch
Depends on the type of rocker and the panel it is mounted in.
Silvertip
Re: Rocker switch
Normally, a plastic tab at the top and bottom of the switch housing compesses as the switch is pushed into the panel. Those tabs then spring out to lock the switch in place. Squeeze the tabs and push the panel back out of the panel. You may need to loosen the panel and pull it forward if you can't get to the switch because of where the panel is located.
