biederboat
- Feb 13, 2005
- 91
Hi, got a 1995 90HP Force, starter motor won't turn over when properly installed but does turn over quite well when directly powered off the engine. I can hear the solenoid clicking but a test light doesn't light up on the starter side of the battery circuit (from the solenoid to the starter). The ignition start circuit seems good and it still won't turn over even when I connect the hot side of the start circuit (from the key switch) directly to 12 volts and clip on a direct ground lead on the ground side. I guess what I'm saying is I've identified the solenoid as the culprit but it makes its normal "click" noise so I'm asking can they fail yet still sound as if they're functioning okay? I've never seen this happen on a device such as this.
Thanks,
Biederboat
Thanks,
Biederboat
