My '95 Force 90 has started an intermittent high RPM problem at idle and at throttle (prop hub is fine). RPMs will jump from 500 to 2500 at idle and back to 750-1000 range again, then back to 2000-2500. This is happening with no change in throttle or anything else. A couple times this occured then the RPMs returned to normal idle so I gave it a little throttle. RPMs shot up to 5000-6000 range under very little throttle. This has occured on my last 2 outtings but sometimes the motor behaves as perfect as it has for the previous 12 years.
any clues???
any clues???
