Re: depthfinder power cable
Cut two pieces of shrink tubing a little longer the splice. The tubing must cover the entire splice and a portion of the insulation at each side. Slide a piece of tubing on each wire. If the tubing is large enough to cover both wires, slide a third piece over both wires well away from the other two. Make the splice (solder or crimp). If you solder, wait until the splice cools and then place the heat shrink over the splice. Using a match, heat the tubing. It will shink and seal the splice. Rotate the wire so heat is not concentrated in one spot. When both splices have been made, slide the third piece of tubing over the other two and shrink it. You now have a nice neat joint.
