im looking for spark plug wires for my 1970 Johnson 9.5. not sure which set i need. and is there anything else i should replace when i do spark plug wires. thanks
Inspect the coils closely for cracks in the housing. Inspect the points while you're in there too. Make sure there's lots of material left and clean them up with a point file. If you need to replace the points you should do condensers at the same time.
