I am replacing the water pump and have quite a few o rings and seals in the kit that I'm not sure where they go. Does anyone have a schematic for a 2002 200L EFI? I'm specially interested in the shaft seal coming out the top of the pump housing.
OK I got it put back together but I have water comming out of everwhere except the pee tube. Seems like the rubber seal to the copper tube off the top of the pump housing is leaking. Is there a trick to getting that back together correctly? I put the seal in the housing then put the plastic tube into the housing to line up the copper tube. I seems to be leaking around that.
