SpinnerBait_Nut
- Aug 25, 2002
- 17,651
I thought the following was worth trying and that you might be interested.<br /><br />I learned a computer trick today that's really ingenious in its simplicity.<br />Don't know if it will work, but it won't hurt. <br /><br />As you may know, when/if a worm virus gets into your computer it heads<br />straight for your e-mail address book, and sends itself to everyone in <br />there, thus infecting all your friends and associates. This trick <br />won't keep the virus from getting into your computer, but it will stop<br />it from using your address book to spread further, and it will alert you<br />to the fact that the worm has gotten into your system. <br /><br />Here's what you do: first, open your address book and click on<br />"new contact," just as you would do if you were adding a new friend <br />to your list of e-mail addresses. <br /><br />In the window where you would type your friend's first name, <br />Type in AAAAAAA. Also use address AAAAAAA@a.aaa <br /><br />Now. Here's what you've done and why it works: <br />Maybe<br />The name AAAAAAA will be placed at the top of your address book <br />as entry #1. This will be where the worm will start in an effort to <br />send itself to all your friends. But, when it tries to send itself to<br />AAAAAAA, it will be undeliverable because of the phony e-mail <br />address you entered. <br /><br />If the first attempt fails (which it will because of the phony address),<br />the worm goes no further and your friends will not be infected. <br /><br />Here's the second great advantage of this method: <br />If an E-mail cannot be delivered, you will be notified of this in your <br />In Box almost immediately. Hence, if you ever get an e-mail telling <br />you that an e-mail addressed to AAAAAAA could not be delivered, <br />you know right away that you have the worm virus in your system. <br />You can then take steps to get rid of it! <br /><br />If everybody you know does this then you need not ever worry about <br />opening mail from friends.
