  #1
Old May 6th, 2007, 08:17 PM
tim costin tim costin is offline
Default 115 yamaha 115 rough idle in gear
I have a 17' runabout that I use for lake and ocean here on Vancouver Island.I bought the boat 3yrs ago.When I first used the boat, the motor would cough and die.I took it to the dealer and he cleaned the carbs.This cured the hesitation when opening the throttle(I waterski).The problem I still have is that the motor runs poorly in gear above idle.Once I am up to 2000rpm it runs fine.The dealer said the motor runs this way because it is sitting too low on the transom.He showed me the cavitation plate being slightly below the bottom of the boat.He said the motor needs to be moved up two holes as there is too much spray coming off the motor(they water tested it).This would be about 1".I realize that it is a 2 stroke and will never run as smoothly as a four.Any suggestions?
  #2
Old May 6th, 2007, 10:26 PM
yamamarinetech40 yamamarinetech40 is offline
Default Re: 115 yamaha 115 rough idle in gear
Find another dealer....there is absolutely no connection with mounting location and performance between 1000-1500 RPM...does sound like it needs to come up IF there is a lot of spray being generated from midsection....you say you bought the boat three yrs. ago and already dirty carbs..so used, right? What year is motor? Why did dealer give it back to you less than perfect and why did you accept it? Probably still carbs....hard to tell
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Rough idle - dies in gear - Please help! eclipsme Other Outboard Brands 5 August 21st, 2009 07:30 PM
225 yamaha rough idle in gear kona-jack Yamaha & Suzuki Outboards 8 November 4th, 2005 01:25 PM
New Tohatsu 40hp, missing/rough idle in gear james082273 Honda & Tohatsu/Nissan Outboards 10 March 18th, 2004 08:00 PM
yamaha 25 rough idle yamahaman Yamaha & Suzuki Outboards 0 January 25th, 2004 09:36 PM
93 C85 Yamaha Rough Idle bproctor123 Yamaha & Suzuki Outboards 7 November 30th, 2002 06:31 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
