Evinrude 6HP Won't Stay in Reverse
Evinrude 6hp model# E6REDD late '90's model I believe. It will pop out of reverse unless you hold the shift lever there. Forward and neutral work fine. The lower unit gear oil is clean and at the proper level. I can not see any way to adjust the shifting mechanism. Does anyone have any ideas? Thanks
