1973 Johnson 65 HP problem HELP!
kidralph
This engine will start fine and run at low RPMs. When I give it more throttle it takes off and will run about 15 seconds then shuts down abrubtly. It seems to be getting fuel so I think it must be something electrical. any ideas ?
muskrat
Re: 1973 Johnson 65 HP problem HELP!
does it run better with the choke on when it starting to die..
steelespike
Have you tried squeezing the primer bulb when it tries to die?
kidralph
yes, it will seem like it wants to run a little better when the choke is on but it is only temporary and it will still die
kidralph
No the primer bulb stays hard even after the engine dies. At first I thought it may be the fuel pump but usually the bulb will go soft when the pump isn't working........ right?
