  #1
Old May 1st, 2007, 11:26 PM
jethro66 jethro66 is offline
Default size of piston 1972 25hp. evinrude 25203r
Hey guy's I have a question,I would like to rebore my cylinders on my motor and just wanted to know what size of piston and ring's do I need to get after a rebore? how much doe's a rebore cost?
  #2
Old May 1st, 2007, 11:30 PM
F_R F_R is online now
Default Re: size of piston 1972 25hp. evinrude 25203r
First things first. First locate a shop that can do the job. They will quote you a price and look at your cylinders and tell you how much needs to be bored out. Then locate replacement pistons before doing the bore job. Just in case there is a problem getting what you need. The shop can fit the piston clearances to specs.
  #3
Old May 1st, 2007, 11:44 PM
Ok ,so they can be bigger piston's?
  #4
Old May 2nd, 2007, 10:46 AM
Chinewalker's Avatar
Chinewalker Chinewalker is offline
Yes, you would get a piston that is slightly larger in diameter. However, you are looking for oversize pistons on a motor that hasn't been made in over 30 years. Try the long-established dealers first - they might have something tucked away in a dusty cabinet...
Around here, rebores generally run between $40 and $50 per hole...
- Scott
__________________
Share A Project Page for 1971 GW Invader Banchie 13
http://www.shareaproject.com/pages/p...,p,433,00.html
Share A Project Page for 1976 American 18
http://www.shareaproject.com/pages/p...,p,404,00.html
Share A Project Page for 1974 American 15
http://www.shareaproject.com/pages/p...,p,405,00.html
  #5
Old May 2nd, 2007, 11:13 AM
Quote:
Now I'm wondering if it really needs to be rebored. Why do yiou want to do it? Are the cylinders damaged? It is folly to rebore a motor that doesn't need it.
  #6
Old May 2nd, 2007, 12:46 PM
I agree. If you're reboring thinking you'll get "BIGGER" pistons, it won't work. Bigger pistons do not give you more performance. Oversize pistons are balanced and cast to give as equal performance to original size as possible, as they are often replaced singularly, not necessarily as a set. Oversize pistsons are typically used when a ring lets go and scores the cylinder walls to the point where the only way to repair the damage is to bore the cylinder out. Also used when the cylinder is just plain worn out and is out of specified tolerances...
- Scott
__________________
  #7
Old May 2nd, 2007, 04:18 PM
No, compression is 90 on the top and 115 on the bottom. figured I had a blown head gasket so I took it apart and inspected it ( blown with a teaspoon of water coming out0. I found 2 pot's on the cylinder wall and some pisaton damage and lot's of carbon deposit in the exaust housing.piston size is .030
  #8
Old May 2nd, 2007, 04:32 PM
It's already .030? Unless you can get it sleeved, it's good-by for that one. .030 was the largest oversize made for that year.
  #9
Old May 2nd, 2007, 04:33 PM
iwombat's Avatar
iwombat iwombat is offline
Can your scored jug be honed mostly clean? A minor scratch or two after honing isn't the end of the world either. I think your real problem was the blown gasket. If the bores are in spec, I'd hone it button it all back up and see what kind of compression you can get. Worst case, you take it apart again and get it bored. Best case, you're back on the lake.
  #10
Old May 2nd, 2007, 04:35 PM
iwombat's Avatar
How badly are the pistons scored? A few minor scratches - still usable. Looks like it's been dragged through gravel - not usable.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Little help please 1972 25hp evinrude jethro66 Johnson & Evinrude Outboards 2 April 14th, 2007 07:52 PM
1972 25hp evinrude problems 7magman Johnson & Evinrude Outboards 1 April 27th, 2004 09:10 PM
1972 Evinrude Outboard 25HP babybooha Johnson & Evinrude Outboards 7 October 22nd, 2003 08:19 AM
1972 25hp evinrude, type of oil? BBMAXX Johnson & Evinrude Outboards 1 September 9th, 2003 08:00 AM
1972 25hp Evinrude won't run geofisherman Johnson & Evinrude Outboards 2 March 16th, 2003 03:04 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
