Re: Powerhead Match
Yes, yours is a crossflow. A looper is physically much bigger and has no plates bolted on the side or back of the block. Your crossflow has by-pass covers bolted to the side (each cover has 6 bolts) and the exhaust plates bolt on at the back of the block.
Any crossflow in those years mentioned above will bolt on without any mods. The "bubble back" exhaust is simply a tuned exhaust. Well, that's the theory anyway.
Anyhow, to make things simple look at your 90 block where the front half meets the block. Basically the crank center line. At the bottom there is a cast in mount with a rubber in it. A bolt goes thru that rubber into the lower pan.
When you're looking at possible "donor" motors look for that cast on mount. Earlier V4 crossflows have that mount bolted to the front half with 2, 1/4 x 20 bolts. Just to simplify let's stay away from them. Some will fit, some won't but the ones with the bolted on lower mount have a small center main crank and the wrong mounting bosses for your power pack.
Look at how your pack is bolted on (top of block, port side toward the rear). Make a note of those bosses. To really simplify things the donor block needs to have the same bosses so the pack will bolt on easily without fabricating anything.
Is there something wrong with your 90 now?
