48SPL High Temp Switch
Lundman88
Tell tale stream is strong even at idle, new W/P and new thermostat. All water passages appear to be open through block and head. High temp alarm goes off after about 15 mins at idle. I suspect high temp switch is faulty. Does anyone know what temperature the switch is supposed to trip at?? Part number 538441 temp switch is not available from Crowley. Is it available from OMC?
