Re: Yamaha T9.9 Oil Drain Plug
I already did check the oil for water and it's definetly not that. Besides it's a fairly steady stream and if there was a leak from the drain plug there would be oil residue present. It seems to be coming from around the teflon washer. There is a gap between the washer and the upper unit housing and I can see I believe a o ring around the oil drain tube which makes a seal to the housing unit. What is above that o ring in the void space other than the oil drain tube as I believe there is water getting into that void space.
