reelfishin
- Mar 19, 2007
- 3,043
I became the proud owner last fall of a Mercruiser 120 powered trihull, it's appears to be in excellent condition, but hasn't been run in at least 5 years.
I did a few basic checks and the motor looks like it will be fine, it's got good spark, the fuel was treated and the cooling system has traces of antifreeze being pumped through it and let sit, so I don't think anything would have any freeze damage.
The prop was off and the shaft coated in heavy grease, there are reciepts for a new impeller and housing, new prop, new steering teleflex, and a new control cable.
The battery is shot, but I have a good used car battery in it for now for testing, I notice one problem right away, the outdrive will power down, but not up, I can jump out the solenoid at the pump to bring it up, as I did for towing. It stays up with no problem, and hasn't dropped any all winter sitting in my garage.
My question is, what should I be looking for when reviving this for use this year? It's had been sitting outdoors when I found it, but looked to be pretty well covered, so cosmetically it's in good shape.
My concern is with the I/O unit, I have never owned a boat with an I/O. Is there anything I need to check or replace before I put this in the water? I will obviously change the lower unit lube, but was reading here about bellows problems and other seals, and have heard horror stories about bearing failures in these.
I have owned outboards and pure inboards before, and had one early Evinrude Sterndrive boat that had a boot that surrounded the entire drive, this looks much different than that set up.
My main concern is not to do any damage by putting it in the water and finding later that some rubber part was dryrotted and leaking. Is there anything I need to check or should I just lauch it and see? I don't want to be at a busy boat ramp with a problem or a sinking boat.
Any suggestions?
Any suggestions?
