water temp or water pressure gage whats best
Benny1963
ihave evinrude 150 crossflow what would be best water temp or water pressure gauge do you need 2 sending units one for each head and where would you tie in water pressure gauge on 150 v6 crossflow 1981
thanks benny 1963
dreamchaser
Re: water temp or water pressure gage whats best
benny, as for temp gauge ..u will need 2 senders and 2 gauges ...water pressure just 1 ... i believe pressure gauge ties into pee hose ......
jimmbo
Both would be best. Pressure gauges are more widely used. They can give a false sense of security under some conditions. They read pressure whether it is water pressure or steam pressure. If your motor has a weak or damaged water pump or a leak in the supply line to the engine it might not be able to fill the block completely to the top. If that were to happen the upper cylinders will run hot and any water hitting them could be turned into steam and the pressure will rise. This used to happen on Merc inline 6s, top two cylinder would melt from lack of water and the owner would swear the pressure gauge was reading fine or higher than normal before meltdown. This also happened when the engine was over trimmed or was raised high enough on the transom to interupt a solid supply of water to the inlets.
dreamchaser
GIVEN ALL THAT ......U WANT TO HAVE FACTORY TEMP SWITCHES INSTALLED ON BOTH HEADS THAT WAY IF 1 HEAD GETS HOT THE ALARM WILL SOUND
jimmbo
A lot of V6s have a temp switch in each head to sound the overheat horn, or to tell the computer to switch to SLOW mode.
