Re: water pump 150 crossflow 1980
If the pressure relief valves are not deformed, reuse them. They distort and melt if they get overheated. If used in salt water, you may prefer just to replace all the valves, grommets, springs, washers etc. They are not that expensive. Replacing the stats is a good idea.
