Wiring harness help for Yamaha 703 Control
I bought a 2004 T9.9ELR Outboard with 703 Control unit. I am having problems with the wiring harness for the outboard. It has a 7 pin harness that goes from the motor to the 703 controls. As well the motor has the positive and negative leads that go to the battery. The wires from the harness enter the control unit and go to the different switches with the exception of the pink wire which is left blank. There is also 5 wires that leave the control unit and go ?. They are color coded blue/green/yellow/2Xblacks. The problem I am having is the motor will not shut off via either the switch or the safety lanyard switch. I am thinking that one of these 5 wires needs to be connected to something (possible the battery). The harness from the motor has 7 wires pink/left blank, white/to ign switch & safety lanyard, brown/micro switch then to ign switch, blue/comes in with harness wires but not connected to any switches and is one of 5 wires which leaves the control unit, green/comes in with harness wires but not connected to any switches and is one of 5 wires which leaves the control unit, black/to safety lanyard and ign switch, red/to ign switch. The motor starts and runs fine but when I turn the key back it doesn't want to shut off. Also are any of these wires used to charge the battery or is that done through the cables that leave the motor and go to the battery for starting, and just reverse the energy flow when the motor is running? If you can't understand my explanation I can send you diagram I have made up any help would be greatly appreciated as it's going to take about 2 weeks for a local dealer to get me a manual. Happy fishing
