rebuild scarab 30 ft sport center console
Edward Wax
I recently bought a 30 ft scarab sport center console. All the wood stringers and transom are rutted out, i would like info on replacing all of the above, also wood between hull.Are there blueprints available fo this boat. iT IS A 1982. aNY INFO WOULD BE GREATLY APPRECIATED
tashasdaddy
Re: rebuild scarab 30 ft sport center console
i doubt you'll ever find any blue prints. Scarab going to keep their secrets. it's just like doing a small boat, just one heck of a bigger scale. for better advice, post some pictures. upload the to photobucket or the like. then on your thread clik the yellow box next to (More) back space the line clear the paste the url of the pics.
Chris1956
Ed, Hopefully there is enough left of the originals to figure out what size they were. Likely 2 by lumber. I recommend dry solid pressure treated lumber for stringers and 1/2 dry pressure treated plywood for the floor. Several layers of 3/4" PT Plywood for the transom. Try to match the original dimentions.
Solittle
What do you mean "wood between the hull"?
Pictures would also help.
Most of the how to's are already here - - take the time to read them.
