  #1
Old April 27th, 2007, 01:21 AM
Tyler785 Tyler785 is offline
Default 76' Evinrude, 55 hp, remote control box, ign switch prob. HELP!
I got my control box back together ok. now it ides really high when I start it so I have to shut it off. it seems that when I go forward and backward and try to come back to idle it fails to go all the way back into idle and starts to rev really high again. sometimes it will slip out of that plastic gear in the control box and get stuck coming back to idle as well. I tried to move the cables around because they were pinched last time I had to fix the coming out of gear problem
  #2
Old April 27th, 2007, 02:29 AM
Seasport Seasport is offline
Default Re: 76' Evinrude, 55 hp, remote control box, ign switch prob. HELP!
Check out the fuse in the big red holder in the motor. Sounds like you have blown that.
Not sure why you have disassembled the switch to get at these wires.
For a parts diagram see
http://epc.brp.com/default.aspx
  #3
Old April 27th, 2007, 11:46 AM
Thanks for the info about the fuse. I didn't disassemble the switch. I had to take off the cover for the remote control box and throttle lever to get to the back of the ignition switch.
  #4
Old April 27th, 2007, 02:10 PM
Kevin W Kevin W is offline
Even though I have been there done that type of thing.
disconnecting the battery can avoid alot of trouble.
  #5
Old April 27th, 2007, 02:13 PM
ok. thanks for the tip!
  #6
Old April 29th, 2007, 03:48 PM
bump to top
  #7
Old April 29th, 2007, 03:56 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Tyler.... I've been following this thread but unfortunately your problem is a case that, in my opinion, could be helped only if I or another member were there to help physically..... that is pertaining to the parts being assembled within the control box properly.
Obviously something within that box is not where it should be but we have no way of knowing what. Is there anyone in your area that is knowledgeable in the marine line that could take a look at it?
  #8
Old April 29th, 2007, 06:39 PM
ok. that's what I figured. I am waiting for a call from a guy that I bought the boat from who works on boats. He already fixed it once before it did the idle thing. Thanks or the help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Quicksilver 3000 Classic Remote Control Trim Switch TommyRox Tracker Boats 2 January 3rd, 2007 02:49 AM
Evinrude 'Simplex' Remote Control jackhartjr Johnson & Evinrude Outboards 6 October 4th, 2006 10:59 PM
83 Evinrude 25 kill switch prob. 58 Alumacraft Johnson & Evinrude Outboards 0 August 10th, 2006 09:26 AM
OMC Remote Control for 98 Evinrude 50 HP RCCola Johnson & Evinrude Outboards 3 November 10th, 2002 03:28 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
