Re: 1997 Merc 75HP
Word to the wise. The head where the plug screws in is aluminum. Very easy to strip. When I was younger I thought things had to be really tight.....knew nothing of torque specs.
I stripped the threads on numerous fastners including a lawnmower and OB motor.
So, when he reinstalls the plugs, pull them down till the wrench stops turning with light pressure and then give the end of the wrench a moderate tap with your hand and leave it at that.
If you are installing new plugs, the seal will have to be compressed so you will experience mild resistance as it is compressing, but when it is fully compressed the resistance goes up sharply. Stop there and give here the last tap.
Mark
