  #1
Old April 26th, 2007, 03:53 PM
Rudderman Rudderman is offline
Default Yamaha Starter Motor Help Please
Hi, I'm having trouble with my starter motor...see attached thumbnail for summary of problem.
Inside the starter motor housing, down where the positive terminal bolt goes through the casing to connect with the brushes, is the bolt supposed to be brazed onto the brush wire or does it just rest beside it?
On mine, it seems to rest beside it, but its hard to know if maybe it is supposed to be a more solid contact (ie brazed or soldered or something)
I think this intermittent connection is causing the problem. When I disassemble the thing and then reassemble it, the motor works fine, then goes back to just clicking the relay. I know the relay is good cos I have tried a direct connection to the battery too.
Previous history of engine:
Yamaha F15 1998 model, four stroke electric start engine.
Engine was submerged while running 3 years ago, was cleaned out and has run perfectly ever since.
Recently, the starter motor has been giving trouble....when you press the start button, the relay clicks but the starter does not turn over at all.
I have the Clymers manual, so I disassembled the starter motor as per instructions and found the starter motor full of watery mucky gritty stuff.
I cleaned the whole thing meticulously, including brushes, armature etc, polished the commutator plate with really fine sandpaper.
Thanks for your help, this is a frustrating problem!
Last edited by Rudderman : April 26th, 2007 at 04:15 PM. Reason: thumbnail attached
  #2
Old April 29th, 2007, 03:37 PM
JUSTINTIME's Avatar
JUSTINTIME JUSTINTIME is offline
Default Re: Yamaha Starter Motor Help Please
it should be connected to the post
__________________
HUMAN BUILT = HUMAN FIXED
CERTIFIED MARINE TECH
  #3
Old April 30th, 2007, 09:14 PM
Thanks. The connection must have broken off at some point. I was able to braze it back on so it should be fine until I get the new brush kit arrives.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 200 hp starter caldemaxi Yamaha & Suzuki Outboards 14 May 3rd, 2009 07:54 PM
20 hp starter coil / starter motor HELP harry101 Johnson & Evinrude Outboards 2 October 10th, 2004 09:46 PM
2002 Yamaha 115 starter sounds like it is not engaging motor tjfreemanjr Yamaha & Suzuki Outboards 7 October 26th, 2003 12:00 PM
starter motor will not fire only clicking noise heard which is not in starter Omega Man Johnson & Evinrude Outboards 6 September 16th, 2003 02:43 AM
Year of old Johnson motor and starter relay wiring... starter/battery rod925 Non-Repair Outboard Discussions 1 July 26th, 2003 02:51 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
