  #1
Old April 25th, 2007, 10:13 PM
LesH LesH is offline
Default 15 HP Mariner loses power
I have a 1997 15 HP Mariner tiller outboard. Bought it used this past winter. The motor's had little use and was very clean.
Previous repair was the switch box had been replaced with a used one. Compression was good and even. The motor had sat for awhile and the float needle was stuck. Bought a Seloc manual and rebuilt the carb. including primer and fuel pump.
Checked Hi and Lo speed timing. Both to spec. New fuel lines on Carb., new vacuum tubes and gas line and tank.
New spark plugs both evenly tanned and dry. Lots of spark, grounds tight, coils test OK on Ohm meter and no cracks or burns,
Reed valves are good, no cracks and all look even. Carb. gasket, good doesn't appear to be any air leaks.
Timing advance moves freely. Lots of cooling water spitting out.
The motor runs like a champ cold and doesn't miss a beat when hot, as long as I don't idle. When I reduce the throttle and troll the motor works great. When I open the throttle up again it accelerates very slowly and sometimes won't even get the boat up on plane.
The motor sounds fine, just no power. It's like I've barely cracked the throttle even though it's wide open.
I've looked at the throttle plate and it's wide open. Sqeezed the primer bulb and it's firm. Sprayed extra gas into the carb. and no change. I spray WD around the carb, gasket. No change.
Here's the weird part. If if put the motor in reverse and give it gas, it will rev. high like it's suppose to. Now, when I go forward it's good. It doesn't accelerate as fast as when it's cold but it will get the boat up on plane.
I'm stumped. I'm thinking that I might have too much float. When the motor warms up and I idle, it causes the motor to become overly rich and it boggs down. When I put it reverse there's less load on the prop and this allows the motor to rev. high and uses up the gas from the over rich condition. There is a little gas in the vacuum lines. Is this normal? Or am I mistaken and these lines are fuel over-flow lines??? One runs out of the carb. comes to a "T" with one line high and one line low on the crank case.
or
This motor has a theromstat. It appears to open and close fine. Could it be heating up the motor. I've read about an over heat slow down function but I don't know if this motor has it. I don't see anything in the manual. Could it be getting hot and when I idle I can't accelerate until it cools. The slow down funtion is only for forward so when I rev it in reverse it pushed extra water through the motor and cools it down enough for it to accelerate in forward.
or is it ignition. I hate to spend big money on ignition part without some clear indication that this is the problem.
I hope it's something simple, but as of now I'm out of ideas.
Your thoughts please.
  #2
Old April 25th, 2007, 10:27 PM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
Default Re: 15 HP Mariner loses power
Adjust your idle mixture screw 1/4 turn richer than smooth running. It needs that extra gas for acceleration. If you adjust for smoothest idle, it'll bog and die every time.
The tiny hoses are recirculation lines. They move puddled gas from one cylinder to another to be burned. Puddling occurs at low RPMs.
The motor will rev easier in Reverse because of the prop blades. In reverse, the blades are swept back. If forward, the blades are cupped.
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #3
Old April 25th, 2007, 10:32 PM
SO, clockwise until it's ruff. Counter-cockwise til it's ruff. Count the turns, set the screw half way and then 1/4 turn counter-clockwise???????
  #4
Old April 28th, 2007, 04:48 PM
rafiqi1 rafiqi1 is offline
I have exactly the same problem.
No power will barely plane.
What was your compression reading?
Mine started @90 psi and then next time it was only 60 psi.
Please let me know if you had a fix.
Thanks,
Rafiqi.
  #5
Old April 30th, 2007, 11:17 PM
Did a compression test today. 110 psi on both cylinders.
Still haven't got my problem fixed.
WillyBWright. Thanks for the quick response.
I think your very close to being right.
I ran right out the next morning and adjusted the low speed mixture screw as you stated. The motor ran like a champ. Turned if off and started, trolled, accelerated all good. Went through almost a tank of gas. I really liked my motor. Right at the end I slowed down and tried to accelerate again and nothing. No amount of tinking would fix it. I felt like loosening the screws and dropping her off the transom.
Took the carb. off and took it apart again. I swear, I've done this so often, I can do it with my eyes closed. Everything looks good inside, very clean. I took the float off and let the float swing arm hang down. The float valve seemed to stick a little bit. I took it out and polished the hole with a Q-tip and carb. cleaner. More cleaner and air blown through all holes.
Very clean not sticking. Looking at the float. Not exacly at 1 inch. When I was rebuilding the carb. the diagram for setting the float had been omitted from the manual. I e-mailed Seloc and had a diagram within 24 hrs.
It shows the float set at exactly 1 inch. I assume this is critical. My float has a shoulder on it which is different from the diagram. When I say shoulder, I mean one side of the float is narrower that the other side like a raised rim.
Is the shoulder counted in the 1 inch? Is the measurement actually 1 inch? Should I replace the float with one that looks like the diagram??? I have an older WM carb. that looks the same as the WMC 49 that's on my motor. The float in this carb. looks the same as the diagram both in the manual and the parts list.
Put the carb. back on and it ran good for 15 minute then back to the same old. One thing that is curious. Everytime I take the carb. off, take it apart, put it back together and put it back on the motor the motor runs great. The performance goes down hill until it won't plane. The day I adjusted the screw as you instructed was the best it's ever ran.
Frustrated.
I checked everythink else today. Tons of spark. Thermostat opens an 120. all hoses tight. Throttle plate moving. All fuel line hose connections tight.
I'm sure it's fuel and I'm sure it's very close to being fixed.
Your thoughts,
Thanks in advance.
LesH
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
9.9 mariner loses power souwestnova Mercury & Mariner Outboards 3 March 13th, 2007 10:44 PM
1995 Mariner 90 loses power talsum Mercury & Mariner Outboards 1 May 10th, 2006 07:24 AM
1999 150hp mariner periodically loses power antpearse Mercury & Mariner Outboards 2 November 29th, 2005 10:14 PM
75 HP Mariner loses spark? waveraider Mercury & Mariner Outboards 5 April 11th, 2005 07:56 PM
Mariner 90 Loses SPARK after a few seconds. mwdebard1 Mercury & Mariner Outboards 3 June 16th, 2004 10:31 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
