I just bought a '94 ProCraft V180C and took it out for the first time. Everything ran great for about 1.5 hours from idle to WOT. Stopped for lunch and fishing for about a half hour. Started right up with no problems and ran fine until I would go WOT. After a few seconds the motor would die down (lose power) as if struggling for fuel, and if I backed out of the throttle the motor would run well without any skipping, misfires, etc. The problem would only reappear if I went WOT. I wasn't paying attention to the tach at the time of the problem so I can't say what the rpm's were, but it seemed the motor would run up to 40mph without a problem. The previous owner had tuneup work done last June and never used the boat after that, so the plugs, fuel filters, etc. had 0 hours to them prior to my trip. Only new fuel and oil used. I've done lots of auto work, engine rebuilds, tranny swaps, etc., but am new to the marine world and had to do very little ignition/electrical work asside from swapping out starters and alternators. I bought a SELOC manual for the motor but it's not very clear regarding the ignition system. Any recommendations for learning more about the outboard ignition system on this motor (videos and such)? I usually learn something one of two ways; I either mess up a couple times before I get it right or I learn watching someone else do it right the first time and the stator seems too expensive to learn a lesson by messing up without a thorough troubleshooting.
