Re: Pontoon Prop Advice Needed
It seems from the Etec tests I've seen that your prop will be in the 13" range when you are set up right with a speed around 21-22 mph.
Unfortunately there are no pontoon tests for your motor.
As I said before the 50 pushes a 24 ft toon at 19.5 mph with a 14/13 at 5,375
and a 21 ft at 21 W 13 3/4 X 13 at 5,500. the 50s max rpm is 6,000. and your 75,range is 4,500 to 5,500.I would think if you can hit the setup just right you would be in the 22+ range with at least w a 13' pitch.
