  #1
Old April 19th, 2007, 04:24 PM
rogueriver rogueriver is offline
Default Info on evinrude 9.9 cooling
Hi;
I just got an Evinrude 9.9 ser #E0001099, mdl #10625R. I've only ran it in a barrel so far and it takes about 5 minutes and then a small spray of water comes out exhaust. Is this normal? Once it starts spraying does it continue? My only experiance with outboards were larger Johnson and merc motors and they shot a steady stream at startup. Also the party I purchased the motor from was not sure of the year model? Thanks Rogueriver
  #2
Old April 19th, 2007, 04:55 PM
ezeke ezeke is offline
Default Re: Info on evinrude 9.9 cooling
The model # is for a 1976 9.9HP Evinrude. It did not come with an "overboard indicator" or "tell-tale". When the engine is running the exhaust housing fillls with exhaust and water and water should spit out of the holes on the back of the mid section. You may get more water if you set the motor in deeper water, several inches above the anti-ventilation plate and at least enough to cover the water pump.
  #3
Old April 19th, 2007, 05:17 PM
BoatBuoy BoatBuoy is offline
Here's a website that has a LOT of info about 9.9 motors. Scroll down to the bottom.
http://www.wisnersinc.com/Fishing%20...info_main.html
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Cooling of an evinrude 9.9 phralh Johnson & Evinrude Outboards 10 November 21st, 2006 08:33 PM
Evinrude cooling fredde Johnson & Evinrude Outboards 5 August 31st, 2006 12:53 PM
82 V4 Evinrude Cooling kjglastron Johnson & Evinrude Outboards 3 June 5th, 2005 06:37 PM
Evinrude Cooling aztecrdt Johnson & Evinrude Outboards 1 May 20th, 2004 04:16 AM
Cooling on 2.5 Evinrude evinrude 2.5 Johnson & Evinrude Outboards 1 May 30th, 2002 01:22 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
