Re: Clutch dog chattering
have you tried to adjust your control cables. 17 year old cables streach. disconnect cable and shift manually and see if it will stay in gear. when putting in gear, it is a quick thrust, not the slow, let's listen to the clogs interlock. the slow shift is part of what wears the edges of the dog off. the are very square gears. lube won't fix it. you can rebuild the lower unit.
