hi,
I'm planning to decarb my "new" outboard, 84 evinrude 90 hp with vro. I've read some posts here. I'll summary the steps I think I should do(I think I'll use the reg. seafoam and not the spray), any advice/comments is appreciated. thanks.
1. mix 1 can of seafoam with 1 gal. of gas in a seperate tank(let's call it the mixture tank). I'm just wondering if I'm mixing too much seafoam here, I think instruction calls for 1 oz per gal or so.
2. bring motor up to operating tem. using regular gas tank.
3. disconnect fuel line from regular tank and connect it to the mixture tank.
4. run motor for about 10 minutes, adjust throttle to prevent her from dying.
5. shut her down and let it sit for about 30 minutes.
6. run her again with regular tank and watch for gunk/smoke.
how do I know if I should repeat with the mixture tank, what are the tell tale signs? thanks
