Tiderunner18
- Feb 24, 2007
- 18
This morning, I drug home a 1985 18' Tiderunner with a OMC Sea Drive (140hp, I think?) that hasn't run in a good 10 years or so. The motor is locked up so I started with shooting lots of penetrating oil in the spark plug holes but only managed to get the flywheel to turn back and forth a degree or two. I pulled the heads off and the cylinders had a little surface rust but nothing terrible so I'm thinking the pistons aren't siezed. Any ideas what might be locking things up? Broken crank/rods? Water Pump? The guy I got the boat from says he had it serviced by a local shop before it was stored and it ran fine at that time, so I wouldn't expect the bottom end to be blown up.
Thanks!
Thanks!
