  #1
Old April 13th, 2007, 10:40 PM
fireman_103 fireman_103 is offline
Default 1976 evinrude 85 cooling tubes
I recently got this motor off a friends boat and wow at the small problems. I changed the water pump yesterday and one of the cooling tubes is in bad shape it is shorter than the other and has jagged edges. I put the foot back on anyway and it leaks from various spots. I ran the motor for a short while on muffs and engine didnt seem to get very warm at all. Im gonna have to use it as is for a tournament that is comming up. My question is can i drop the exhaust housing and change the tubes or do I have to pull the power head?
  #2
Old April 13th, 2007, 11:28 PM
ezeke ezeke is offline
Default Re: 1976 evinrude 85 cooling tubes
The water tubes are stock copper tubing sizes, so get a caliper and measure it, buy a piece the same size and a sleeve to tie it together. Then you can solder it. A plumber could do that for you.
  #3
Old April 14th, 2007, 02:25 PM
I went and took another look at the tubes they are going to be to far up in the ehxaust housing to do any soldering of new tubing on them. How hard is it the remove the housing? Looks like the power head may have to come off to ge to a couple of bolts? Does anyone have a diagram of the removal proceedure.
  #4
Old April 14th, 2007, 04:21 PM
F_R F_R is offline
The tubes are attached to the powerhead adapter by a flange. Yes, the powerhead and powerhead adapter has to come off to replace them. Not a small job.
  #5
Old April 14th, 2007, 04:26 PM
dsinger dsinger is offline
All the powerhead bolts except the powerhead stud nut plus four in the pan. It can be removed without pulling the powerhead with the proper tools. Watch out for breaking bolts. I would change the t-stat while you are there or at least test it. Pretty simple to solder just clean it up with plumbers sandpaper, flux, and solder the couplings. Make sure you buy hard copper not soft. Best way I have found it makeing them long then cut to the proper length that way it will bevel the end that goes into the water pump. Solder is simple just heat the middle of the cupling and alow the solder to flow through the fiting. If it on its side you only have to touch the top side and it will flow.
  #6
Old April 15th, 2007, 01:30 AM
It sounds like it would be just as easy to swap the power head to the housing that my 115 is on. The tubes are fine on that one. Think Ill save alot ot time by doing this. Figure I can take the 115 power head off in about an hour then the 85 head off and back on in about two hours. What do u think??
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1976 Johnson 9.9 Cooling problem Fish mojo Johnson & Evinrude Outboards 12 May 6th, 2007 05:49 PM
Eska 1976 5.5HP cooling pwheatla Other Outboard Brands 1 March 5th, 2006 10:56 AM
Cooling system....1976 Evinrude 135hp willisballs Johnson & Evinrude Outboards 1 May 4th, 2004 05:14 PM
Obstructed Cooling System 1976 55hp Evinrude tdfields Johnson & Evinrude Outboards 1 August 6th, 2003 07:47 PM
replacing water tubes on a evinrude 115 bhbumper01 Johnson & Evinrude Outboards 4 June 4th, 2002 09:10 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
