  #1
Old April 13th, 2007, 02:45 PM
Deron Deron is offline
Default Evinrude 5 hp wrong mix ratio
For two outings I have been running my 1967 5 hp angler with a 24 to 1 ratio and was just informed that it is supposed to be on a 50 to 1. It doesn't run smokey or give me any problems. Should I drain the tank and remix? Also what are the long term effects if I keep running on the 24 to 1?
  #2
Old April 13th, 2007, 02:48 PM
iwombat's Avatar
iwombat iwombat is offline
Default Re: Evinrude 5 hp wrong mix ratio
Just for future reference. It's best to keep your questions in one thread, even if you add totally different questions over the course of the conversation.
I answered in the other thread.
  #3
stewart stewart is offline
you don't have to drain the tank, just simply add more oil to the tank. too much is better than not enough. the worst thing you can do to a two stroke is run it too lean.
  #4
Old April 13th, 2007, 02:59 PM
borntobag borntobag is offline
stewart, by adding more oil to Derons tank it will increase the ratio. 50:1 is 2% oil , 25:1 is 4%.
Best thing to do Deron is to use up what you have left in your tank and next time you refil it add the oil at 50:1.
Check the plugs as the excess oil could foul them a bit, but as stewart says to much opil isnt necessarily a bad thing as a two stroke uses that oil for lubrication.
  #5
Old April 13th, 2007, 04:03 PM
Silvertip Silvertip is online now
Or -- determine how much fuel is left in the tank and simply add the same amount of fuel with no oil added. You will end up with 48:1. Otherwise run the remainder of the fuel. It's not hurting anything except the environment.
  #6
Old April 13th, 2007, 04:05 PM
you are correct. i apologize.
  #7
Old April 13th, 2007, 04:37 PM
Scaaty's Avatar
Scaaty Scaaty is offline
Quote:
Man, never do that..wrong guess is fried motor. 24-1 is fine..next tank do it right
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1964 evinrude 28 - ran wrong (rich) mix, now no gas to one cylinder ???? garboj Johnson & Evinrude Outboards 21 October 9th, 2006 06:56 PM
1993 Evinrude 225hp temp gauge reading wrong dbw1356 Johnson & Evinrude Outboards 1 July 19th, 2005 01:33 PM
wrong gear ratio vipzach Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 June 29th, 2005 12:38 PM
Wrong coils for '77 175 Evinrude? Crankstomp Johnson & Evinrude Outboards 8 May 3rd, 2004 02:32 PM
what am i doing wrong. 9.9 evinrude gregs Johnson & Evinrude Outboards 2 April 30th, 2002 08:34 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
