Re: Mariner 225 3.0L repair manual
If you can post the actual serial number someone will hopefully give the factory manual number.
The serial number should be on the swivel bracket.That is the part of the engine that is located between th 2 transom clamps,which are the brackets that hold the motor to the transom of your boat.
DHP
