I was just wondering.I changed the plugs in my 1985 Johnson V-4 90hp and 1 of the plugs had a yellowish froth on it.The motor is running fine and all cylinders are firing strong. What I was wondering is could it be just unburned oil and gas on that cylinder,because before I changed my plugs approx. a couple of hours prior I had turned the motor over a few times to make sure the battery was charged good.
The froth kinda looked like the crud that comes out of your exahust when your running on muffs.
Just wanting to check on this so if it is a problem I can catch it before it gets worse.
Thank you for all your help
