It was an unseasonably warm day yesterday, so i decided to put some fresh gas in the tank and run the outboard.
everything was fine until i tried flipping the Tilt/Run Lever back after putting around. Darn plastic lever broke off in my hand, and there was not enough of it left to get a grip with a pair of pliers to try it turn it. Of course its stuck in the locked position so i can't tilt the outboard back up out of the salt water.
1- Is there a quick fix so I can tilt the outboard back up? (Some other way to unlock it?)
2- Any hints as to how to replace this part?
1993 6 HP Johnson Sailmaster (long shaft) Outboard
TIA !
TIA !
