Re: Drive oil seeping out of water intake slots-96 Alpha
Thanks. Re the acc pump-it has always delivered a good squirt, I left that out. I have the linkage hooked to the inside hole of the upper arm of the acc pump, which delivers the most volume. Oddly, the kit I got had a pump in it but was too small of a diameter, and I had too use the old one which was working. This was after ordering using the numbers off the motor and carb. I called about the ball, they said not to use it. There really is no place to put it, which is why I called the place I bought the kit from. I even put a video on youtube, showing the inside of the carb, trying to get help. Do these 3.0's ever run right, as far as bogging? I'm 53, been around boats a long time, and this one is frustrating me...........
