Re: Mercury 150 XR6 Hard Starting in morning
Good morning
I have a pair of Mercury 175s, 1992 vintage, periodically I have had a hard time with the first start of the morning, especially the starborad engine. When it finally did start, it would put up a huge blue smoke cloud. I even had the fire department called on me once because somebody thought my boat was on fire ! After much checking things out, I came to the conclusion that the auto oil injection system was filling the fuel line and carbs with oil when I left the engines tipped up out of the water overnight. I tried to fix all the components of the oil injection system to fix the problem, but no luck. I removed the oil injection system and went premix and have never had the hard start problem since.
Several times I left the motors down, carbs level, and the hard start problem would not happen. When I left the motors tilted up overnight, they would be hard to start the next day. By the way, even thought they were hard to start sometimes, these motors never failed me by not starting. Anyway, I suggest you check to see if your oil system is the culprit in this problem.
