i have a 072109 prop ,for force 90hp, non thru hub exhaust,i broke the cup ,on the cup theres a #532299.i bought a 072108 prop 13x19pitch i need the cup 15 spline,another thing when i put the new prop its sounds like it scraping on inside,when i took old prop off ,it had a layer of stuck grout on the inside where the inside of prop goes aound,will that noise come off once i run engine a little bit and the grout removed itself,and the thick new paint wears down off new prop???
