Re: Fuel line in a 73 115hp Johnson
The engine started life with assembly 383721 - 5/16 hose on both sides of the bulb. Hose is now #0772564. I don't see why you could not make it 3/8, but both sides should be the same hose, and you would need the larger fitting with the 3/8 barb.
